| | | Forums66 Topics128,163 Posts1,056,918 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 34 | ok i have a 57 1/2 ton with the 235 floor starter and everything but im assuming that the 1957 1/2 tons that where the 283 v8 options did they have the floor startes in them as well is so im looking for one of those bell housings so i can keep the original floor starter in my 57 with a v8 in fron of it | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The only trucks that used the floor starter where the manual transmission 6 cylinder. Hydramatic 6 cylinders and V8 trucks used a solenoid type starter. They also use a different ignition switch that has a "start" position. The floor starter is not compatible with the V8 bellhousing. Side note, the '57 1/2-1 1/2 tons did not have a 283 option. They still used the 265. The 283 wasn't offered in the lighter trucks until '58.
Bill Burmeister | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | I have had numerous late '55 - '59 trucks, none of them that had original v8s had foot starters. Also the '57 had a 265 in it. Check your trim plate. | | |
