9 members (55shaker, fonz8261, Otto Skorzeny, Greg_H, Hotrod Lincoln, Cletus1950, Peggy M, 2 invisible), 150 guests, and 1 robot.
Topics128,131
Posts1,056,721
Members48,454
ok i have a 57 1/2 ton with the 235 floor starter and everything but im assuming that the 1957 1/2 tons that where the 283 v8 options did they have the floor startes in them as well is so im looking for one of those bell housings so i can keep the original floor starter in my 57 with a v8 in fron of it
The only trucks that used the floor starter where the manual transmission 6 cylinder. Hydramatic 6 cylinders and V8 trucks used a solenoid type starter. They also use a different ignition switch that has a "start" position. The floor starter is not compatible with the V8 bellhousing.
Side note, the '57 1/2-1 1/2 tons did not have a 283 option. They still used the 265. The 283 wasn't offered in the lighter trucks until '58.
Bill Burmeister
I have had numerous late '55 - '59 trucks, none of them that had original v8s had foot starters. Also the '57 had a 265 in it. Check your trim plate.
