0 members (),
170
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43941 03/15/2004 9:18 PM | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | I'm replacing my emergency brake cables so I no longer have to use the brick under the back tire. On the replacement cables there are two rubber sleaves. Where do the go? I'm sure this is a silly question but I can't figure it out and there are now directions. I am replacing the originals from my '50 1/2 ton so not much was left. Also, do you have to buy the gasket for where it goes in the wheel or is it advisable to make something? | | |
#43942 03/15/2004 9:39 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Go Cougs...
Take a look at Charlie Brown's post on parking brakes....it is on page 2 or three on the Engine driveline....
Not sure if this will help you or not. | | |
#43943 03/15/2004 10:25 PM | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | Thanks, and yes that is what I have been looking for. My problem was labeling the issue as "emergency brake" in the search instead of "parking brake" My bad! | | |
