1 members (JW51), 186 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
I'm replacing my emergency brake cables so I no longer have to use the brick under the back tire. On the replacement cables there are two rubber sleaves. Where do the go? I'm sure this is a silly question but I can't figure it out and there are now directions. I am replacing the originals from my '50 1/2 ton so not much was left. Also, do you have to buy the gasket for where it goes in the wheel or is it advisable to make something?
Go Cougs...
Take a look at Charlie Brown's post on parking brakes....it is on page 2 or three on the Engine driveline....
Not sure if this will help you or not.
Thanks, and yes that is what I have been looking for. My problem was labeling the issue as "emergency brake" in the search instead of "parking brake" My bad!
