3 members (wvstovebolt, Bill Hanlon, MikeStone1953), 120 guests, and 3 robots.
Topics128,083
Posts1,055,967
Members48,430
#438899 08/05/2008 7:41 PM
Do any of you have a temp gauge on your transmisson fluid lines?
I have '63 with a 327 and a 700R4 Tranny that is being cooled by 2- 6in by 9 in. oil coolers behind the grill. This is the way it was plumbed when I bought it. The radiator has lines for the oil cooler but they were bypassed to the air coolers. Any opinons as to the best route to go for transmisson fluid cooling?
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
Sounds OK to me. I am running a 350 and 700R4 trans in my 55.The only cooler I am using is a small aftermarket cooler mounted in front of the radiator.I have been running this combo for about 5 years with no problems.So if you are using two of them you should be OK.
Be careful not to over-cool the fluid. In the winter, it might be good to use the radiator mounted cooler to help evaporate contaminants out of the trans fluid. The radiator-mounted cooler is downstream of the cooling fins, so the coolant gets a major temp drop before it gets to the trans fluid. I would expect the trans fluid to be somewhere around 175-200 degrees on its way back to the transmission. That should be plenty cool for all but heavy-duty towing situations.
I have a frame mounted cooler. I hope this will suffice. I plan on a temp gauge on the return line.
http://good-times.webshots.com/photo/2334085520099708909MATHQV
~Jim
