4 members (TUTS 59, PAUL Berardi, wilbur53, 1 invisible), 112 guests, and 0 robots.
Topics128,132
Posts1,056,376
Members48,441
Anyone had any experience with the Carter P4740 electric fuel pump?
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
P4740 or P4070? cant find a P4740, however I have used the P4070, used a few of them. You will need a pressure regulator depending on which carb you have. They will feed up to about 400-450hp, then you need to go bigger. I did get one bad one that leaked, however it had been sitting on my shelf for about 3 years so I couldnt return it.
Yep, P4070, thank you. I'm tired of erratic fuel pressure with the stock mechanical pump. I use a Holley/Webber progressive and they recommend this Carter P4070. I don't like the rubber insulators that come in the box, maybe I'll make up something that works better and a heat shield.
