8 members (Donf, Goach2, Otto Skorzeny, cmayna, Joe H, Wally / Montana, Gdads51, 1 invisible),
89
0
Mod | | | Forums66 Topics128,118 Posts1,056,307 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Anyone had any experience with the Carter P4740 electric fuel pump?
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | P4740 or P4070? cant find a P4740, however I have used the P4070, used a few of them. You will need a pressure regulator depending on which carb you have. They will feed up to about 400-450hp, then you need to go bigger. I did get one bad one that leaked, however it had been sitting on my shelf for about 3 years so I couldnt return it.
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Yep, P4070, thank you. I'm tired of erratic fuel pressure with the stock mechanical pump. I use a Holley/Webber progressive and they recommend this Carter P4070. I don't like the rubber insulators that come in the box, maybe I'll make up something that works better and a heat shield.
