5 members (Tronman, Otto Skorzeny, TUTS 59, Millenimech, 1 invisible), 116 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#438530 08/04/2008 4:09 PM
I have a re-built 1954 235 in my 53, I was thinking about putting a dome cover from a 216 on it to get the "look". Some day when time and money aren't an issue maybe a 216 will go in as original. what would I need to do to use the dome cover/valve cover from a 216 on my 235.
Thanks for any thoughts, ideas or suggestions.
Mike
My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man!
1953 Chevy 3100 Shortbed
1965 C-30 Panel Truck
1963 C-20 Long/Fleet Pick-up California Black Plate
http://www.classicparts.com/1947-54-Wayne-Valve-Cover-Stud-Kit/productinfo/86%2D105A/
Tim,
Do you know if there is anything that needs to be drilled and tapped to use the valve cover, will it seal up on the 235 block?
Mike
You just change out 2 rocker arm studs with the studs in the kit that tclederman shows. If you have a 216 laying around or know of one just swap out studs from it.
1949 Chevy 6400
1931 Chevy Firetruck
Mike,
Nothing needs to be drilled or tapped. It seals fine on 1954-1962 235 and 261 blocks. Just make sure the entire bottom edge of the valve over is even/level.
The 4 holes for the machine screws that held the original valve cover in place are covered up by the old-style valve cover.
Tim
Thanks Tim and Cleon.
And don't forget to use an old style gasket.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Thanks Woody.
