9 members (FAST55, Shaffer's1950, John Dlugos, Ponchogl, F100Ranger, Otto Skorzeny, Gdads51, TexasJim50, 1 invisible),
73
Mod | | | Forums66 Topics128,131 Posts1,056,372 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43836 04/12/2004 11:40 AM | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | I DECIDED TO TAKE A SHORT SPIN - BEFORE JUST AROUND THE HOOD 15mph-20 mph max - PICK IT UP 40 mph AND NOT ONLY DID IT BACKFIRE A COUPLE OF TIMES BUT THE TRUCK WAS 'WOBBLING" "SHAKING" SO MUCH IT SCARED ME TO TURN BACK - WHAT IS GOING ON :confused:
jsalchevy63
#43837 04/12/2004 5:56 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Wobbling can be caused by a number of things, from a bad alignment to worn king pins or ball joints, to bad or unbalanced tires, bent wheels, loose steering components, bad spring shackles, bad wheel bearings, etc. A common troubleshooting practice is to rotate the front tires to the rear to see if anything changes, then start looking for loose and worn parts. Have someone turn the steering wheel while you watch for slop in the linkage. After you get everything checked out, take it to an alignment shop and get the alignment checked. Toe out tends to cause wandering and shaking.
#43838 04/13/2004 2:33 AM | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | thanks again 4onthefloor - i'll see what under the hood :p
jsalchevy63
#43839 04/13/2004 10:15 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Did this wobble shake start after the backfire??? :confused: How does the engine run at idle? - Does the steering wheel shake? What other symptoms?
#43840 04/13/2004 11:45 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Check any and all vacume lines! A disconnected vacume hose will instantly tirn any engine into a wild nightmare!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#43841 04/14/2004 1:15 AM | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | all vaccum hoses intact/all sparkplugs connected and clean/after messing with the carb/idle/jets the backfiring stopped/the steering wheel does not wobble/still troubleshooting/ will let you all know :p
jsalchevy63
#43842 04/15/2004 8:09 PM | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | I was following one of the guys in our truck club home one day and saw something fly out from under his truck (1952 Chevy). He slowed down and stopped as soon as he could get off the road. He said it made a loud bang under the hood and started vibrating badly. He looked under the hood and the oil filler cap was off. He thought somehow he built up pressure and blew it off. I went back down the road to see what fell off. It was one fan blade that had broken off. Then we could see that the fan blade came off bounced on the underside of the hood and knocked the filler cap off in the process. A 3-sided blade makes a bad vibration!
Good Luck, Buddy in AK | | |
#43843 04/16/2004 11:57 PM | Joined: Jan 2003 Posts: 35 Junior Member | | Junior Member Joined: Jan 2003 Posts: 35 | my daughters 51 shakes after it has been sitting around for awhile, but it goes away after the bias ply tires lose the flat spots from sitting. duddy | | |
#43844 04/19/2004 12:05 PM | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | the truck does sit awhile -occasionally i take it for a short spin and probably needs to be seen at the alignment shop - i'll keep in touch
jsalchevy63
#43845 05/06/2004 2:20 PM | Joined: Mar 2004 Posts: 31 Member | | Member Joined: Mar 2004 Posts: 31 | took front wheels and tires off front and rolled them in flat concrete - they wobbled so much it was scary - put two old wheels /tires balanced ect. - went for a spin and what a diffrence - truck was 'sober' - there was a bit of to much play on the sterring wheel - what is up with that :confused:
jsalchevy63
#43846 05/06/2004 7:33 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Steering play can be caused by: Worn king pins (or ball joints if you don't have king pins) worn tie rod ends worn steering gear worn spring shackles worn spring eyes or a combo of all of them.
