7 members (Mike in Sycamore, Leo, Gdads51, 1955 1 Series, Bill Trotter, cmayna, ShopRag),
109
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | It's not a 54. From what I can tell, I would think a 1951 300. series. 51 was the first year of the vent glass in the door.It looks like the door handle is the lever type which 51 was the last year. 52 and 53 used a push button. 54 had a 1 piece windshield. Of course, someone could have put a 51 door on a 48 because they fit. | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | to me it looks like a 51 350. ask him to look on the forward part of the drivers door jamb that is where the tag is if it grosses out at 16000 thn its a 350. it should read something like this 50 300 series 301 or 302 with a 24 or a 51 350 series 351,352,353 with a 24(248 ci) following with sequence #xxxx 301-24xxxx 353-24xxxx | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | | | | | | Joined: Jun 2008 Posts: 6 New Guy | | New Guy Joined: Jun 2008 Posts: 6 | Are there any visual clues to tell the difference between a 52 and 53? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | 354 means its a 350 series truck. The 4 tells the wheelbase. 24 means the original motor was a 248. C I believe is where it was made.
Unfortunately I don't recall what city C stands for or what wheelbase the 4 means...
I see the same visual clues that say its a '51. Or at least the passenger side door is a '51. I can't tell if it has an in-cab fuel tank or not. I'd expect that on a '51. Its not a '54 based on the split case windshield.
If you go to OldGMCtrucks.com I think you can figure out the details of that serial number.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Thanks, I think you guys are right on the 51 | | |
