4 members (dt235sd, 3100RustyParts, 54farmtruck, TUTS 59), 75 guests, and 2 robots.
Topics128,213
Posts1,057,488
Members48,473
My 53's fan belt needs to be replaced. What is on now is a machinery belt (all rubber - non steel cable reinforced). I suspect it should be the 'auto' type?
Any input?
rick
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
Big Bolt Shop Curmudgeon
My local auto parts store had the correct (but not original) replacement. One good place to check out is Tractor Supply. Sometimes they have what the auto parts places don't.
Use an automotive belt. But more important, make sure you get the right size and length, then tension the belt properly--not too loose, but don't get it so tight that you mess up the bearings in the water pump or generator.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
Glenn, thanks for the info.
Rick- are there NAPA stores around Montreal? I have been surprised at how much stuff they have for old trucks, and if they don't have it in stock, they can get it over night. If not available north of the border, there must be a store in St Albans or Plattsburgh
Russel, my father owns an auto parts store North of Montreal (UniSelect banner) and a 6 bay garage a little farther down the road. As was the case with my Triumph TR6, there is nothing mechanical I can not get directly from the warehouse (maximum delay is 72 hours). It makes owning a daily driven '53 pickup that much easier...
rick
