0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43768 07/22/2004 1:00 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | I just received a used replacement oil pan for my 1950. It looks like it'll fit but is a little different and want to know if anyone can tell me what the differences are and will it work on my truck.
The pan appears to be the same shape and size and should fit the engine. On the passenger side there are convex indentations that "roughly" look like a "T"
Mine does have the indentations but it isn't as big and doesn't look like a "T"
The new pan also has a small convex indentation at the bottom on the passenger side. I originally thought this was a dent/defect but I don't beleve so.
Mine doesn't look like that. It's smooth.
Any ideas as to what this new pan is and will it fit? | | |
#43769 07/22/2004 1:56 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | I would check a couple of things if it were me.
Place the new pan on the bench next to the old pan. Are the the same height (depth actually)?
Next I would check to see if the pan with out a gasket will bolt up to the block?
If both of these are yes then I would proceed and use the pan. However if the pan height varies significantly then I would proceed with cation.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#43770 08/12/2004 1:51 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Everything appears to be very similar. However, I would like to know what the difference is. I don't want to risk my engine for it. Anyone know the difference? | | |
#43771 08/12/2004 2:31 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | This was just discussed over at the VCCA site. Pop over there and see! | | |
#43772 08/12/2004 3:32 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | I can't find any dicussion regarding this. Can you point me in the right direction? | | |
#43773 08/12/2004 3:58 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Try this: www.vccachat.org (its on the 46-54 forum).
Winona 1949 3100 5 Window Deluxe Cab
