Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (NJC, Wayne67vert, 1 invisible), 166 guests, and 4 robots.
Topics128,281
Posts1,058,471
Members48,490
#43764 06/26/2002 3:54 AM
I'm at the point of putting small block chevy motor mounts into the 38. Checked and they have bolt in or weld on type. Any suggestions on which would be best?
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
#43765 06/26/2002 4:02 AM
Forgot something, I guess I should say these are the steel brackets on the frame. That the motor mounts pin onto.
#43766 06/26/2002 4:36 AM
I think I would go with the bolt in mount brackets and once you know everything is positioned where it needs to be (steering clearance , exhaust , distributor , etc.) you can weld 'em . I had clearance between the top of frame and bottom of manafolds when I first got my truck together and things eventually settled and the manafolds were hitting the frame. Very annoying ! Now I moved the engine forward (got the HEI off of the firewall) and up , also went with headers . Everything clears now !
#43767 06/26/2002 5:12 AM
I was leaning that way already. Most of the reasons you mentioned. Were you able to move the engine forward by getting rid of the old fan and going with the electric's?
