3 members (klhansen, mick53, Otto Skorzeny), 100 guests, and 3 robots.
Topics128,127
Posts1,056,675
Members48,450
#437283 07/30/2008 4:02 PM
How many of you are running a rear transmission mount and how many are not on your AD/T-5 conversion? Any advice one way or the other?
Dave
I've done it both ways with my T5 behind a 235. With the front engine mount and the two bell housing mounts I had some mixed feelings about bolting down the tailshaft of the aluminum-cased T5. With almost 5 feet of frame between the front and rear mounts I had concerns about frame flex placing an undue load on the transmission tail-shaft housing. Because of this, I ran the first 3K miles without the cross member with no evident ill effects.
Recently, I added my own cross made out of 1/2X2" flat stock with angles that let me add a rear mount to the flat S10 pad. However, I added some additional space under the rubber mount for some rubber pads and don't really torque down these rear mount bolts. If you have a brake booster, you may run into some additional clearance issues. The flat stock mounts on the bottom frame rail with a couple 1/2" bolts so dropping it is quick and easy and it gives me the visual effect that the rear is supported. With the heavy sm420 hanging off the bellhousing with no additional rear support, I wasn't really all that concerned.
In my opinion,and after running it both ways, I'd say that if it makes you feel better go for it. If you have booster/master clearance issues I really don't think that on a street machine driven under normal conditions, it wouldn't hurt to run without.
How's that for an ambiguous answer?
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Dave,
Your first paragraph exactly explains my concerns which was the reason for my post. Thanks for your thoughts.
Dave
Riding in the Passing Lane
I put a crossmember under the ones I do. I can' t see letting that long aluminum trans. hang in space like that. They are in Task Force trucks but it's the same setup.
1972 Chevy c10 Cheyenne Super
I have no experience with this...
If I recall from 5 years ago while on a road trip through CA with my 52 when I met a guy with a 1/2 ton with T-5.
While I was looking at his truck, he explained that he used the cross-member from either the S10, or was it an Astro van? and the driveshaft from an Astro van. Supposedly the cross-member fits inside the frame and holes can be drilled to bolt it in, very little work.
Take this as a suggestion that a stock later model cross-member may fit, as again I have not done this.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
