| | | Forums66 Topics128,128 Posts1,056,666 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | How many of you are running a rear transmission mount and how many are not on your AD/T-5 conversion? Any advice one way or the other?
Dave
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I've done it both ways with my T5 behind a 235. With the front engine mount and the two bell housing mounts I had some mixed feelings about bolting down the tailshaft of the aluminum-cased T5. With almost 5 feet of frame between the front and rear mounts I had concerns about frame flex placing an undue load on the transmission tail-shaft housing. Because of this, I ran the first 3K miles without the cross member with no evident ill effects.
Recently, I added my own cross made out of 1/2X2" flat stock with angles that let me add a rear mount to the flat S10 pad. However, I added some additional space under the rubber mount for some rubber pads and don't really torque down these rear mount bolts. If you have a brake booster, you may run into some additional clearance issues. The flat stock mounts on the bottom frame rail with a couple 1/2" bolts so dropping it is quick and easy and it gives me the visual effect that the rear is supported. With the heavy sm420 hanging off the bellhousing with no additional rear support, I wasn't really all that concerned.
In my opinion,and after running it both ways, I'd say that if it makes you feel better go for it. If you have booster/master clearance issues I really don't think that on a street machine driven under normal conditions, it wouldn't hurt to run without. How's that for an ambiguous answer?
Dave | | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | Dave, Your first paragraph exactly explains my concerns which was the reason for my post. Thanks for your thoughts.
Dave | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I put a crossmember under the ones I do. I can' t see letting that long aluminum trans. hang in space like that. They are in Task Force trucks but it's the same setup. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have no experience with this... If I recall from 5 years ago while on a road trip through CA with my 52 when I met a guy with a 1/2 ton with T-5. While I was looking at his truck, he explained that he used the cross-member from either the S10, or was it an Astro van? and the driveshaft from an Astro van. Supposedly the cross-member fits inside the frame and holes can be drilled to bolt it in, very little work. Take this as a suggestion that a stock later model cross-member may fit, as again I have not done this.
Grigg | | |
