BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,777 Posts1,039,282 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jul 2008 Posts: 111 Shop Shark | Shop Shark Joined: Jul 2008 Posts: 111 | Any help is appreciated. Looking for GREY HIGH HEAT engine paint (prefer the type with ceramic in it) SPRAY CAN PREFFERED Thanks
| | | | Joined: Jul 2008 Posts: 111 Shop Shark | Shop Shark Joined: Jul 2008 Posts: 111 | no high heat grey on that site...thanks anyway | | | | Joined: Feb 2000 Posts: 769 Shop Shark | Shop Shark Joined: Feb 2000 Posts: 769 | JR,
You did state you are looking for engine paint. There is New Ford Gray as TM2C stated. It is good to 500 deg. | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | Shop Shark Joined: Sep 2007 Posts: 2,644 | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The only part that gets up above 212 degrees on your engine is the exhaust manifold. You don't even need high heat paint.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | 'Bolter Joined: Jul 2008 Posts: 1,321 |
Harold Is a restoration ever finished? | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | Shop Shark Joined: Sep 2007 Posts: 2,644 | The "correct" color for your engine has been debated to death and our resident color guru Denny Graham has compared the various brands of the gray paint and concludes that the one sold my The Filling Station to be closest to the original color. | | | | Joined: Mar 2004 Posts: 873 Shop Shark | Shop Shark Joined: Mar 2004 Posts: 873 | Plasti-kote universal gray no. 202 engine enamel. Tractor Supply | | | | Joined: May 2007 Posts: 95 Wrench Fetcher | Wrench Fetcher Joined: May 2007 Posts: 95 | Por 15 lists FACTORY MANIFOLD GRAY in high temp
