0 members (), 110 guests, and 7 robots.
Topics128,186
Posts1,057,319
Members48,469
Big Bolt Forum Co-moderator
I found some king pin bushings locally and left my spindles to have them pressed in and reamed. When I was looking at my spindles I noticed there wasn't a hole in the king pin bushing for the grease to pass through. This isn't right is it?
1948 Chevy 2-Ton
Did you find a king pin kit, complete with thrust bearings, shims and pins? If you just found some bushings it sounds like you will need to drill holes in them.
1949 Chevy 6400
1931 Chevy Firetruck
When you get them back, and if the holes don't line up with the grease fittings in the spindles, remove the fittings and drill holes through the bushings.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
My new bushings do have the hole, it was the originals in the spindles that did not have the hole. No wonder they wore out.
1948 Chevy 2-Ton
OK!!
1949 Chevy 6400
Where did you find king pins????
GMC: Get More Cash...
1958 GMC
My Webshots photos
i got my king pins from NAPA
