2 members (Hotrod Lincoln, mo2cyl), 380 guests, and 5 robots.
Topics128,158
Posts1,057,025
Members48,460
My 261 has two ports near the oil line that feeds the external oil filter. One is a 1/4" the other is a 1/2". I'm not sure if they are on a common gallery or different/ I would suspect that the 1/4" pot is the proper choice. Anyone KNOW for sure is intended for the oil pressure gauge?
You can tee off the 1/2" NPT fitting from the lower port that feeds your filter.You can mount a gauge next to the block if you want.The 1/4" hole is plugged on my 261.
Drew
The smaller port (1/8" NPT) is a port that drains to the sump. This port would only be used for the old bypass filter.
I connected my oil pressure gauge to a port near the front of the engine. Between the generator and the block is a 1/8" NPT plug that is common to the galley that feeds the main bearings.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
