Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (UtahYork, klhansen, Otto Skorzeny, carbking, SNOYL, ndkid275), 108 guests, and 2 robots.
Topics128,286
Posts1,058,539
Members48,491
What is the 1/8" fitting on a 58 oil gauge?
It looks like a flare ytpe. If it is how do I flare something that small?
My brake flare kit does not go that small.
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
I think that fitting was used by GM into the 70s. It's actually a compression fitting. I haven't replaced one recently, but if IIRC just cut the end of the pipe off and slip a fresh pipe end into fitting. If your not comfortable using the old fitting NAPA has new fittings in their small parts bin.
Larry
I don't own a vehicle that isn't old enough to drink.
The inside looks just like a 1/4 or 3/16 female brake line type flare.
I ended up putting the 1/8 nut on the copper line then I installed a compression fitting on the line. Next I cut the 1/8 compression fitting off the line leaving only the 1/8 flare type fitting with the compression ring. I then took the dremel and trimmed up the ferrule and tbg.
It works great and I have about 35-40 psig
Regards,
Lindsay
If its at all like an AD gauge then its a compression fitting.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Eaton/Fuller transmissions use 1/8 plastic tubing with compression fittings for the shifter. I have used them before on 1/8 brass before. It may not be correct, but it worked. These fittings are available at heavy truck dealers.
