0 members (),
84
Mod | | | Forums66 Topics128,290 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | What is the 1/8" fitting on a 58 oil gauge? It looks like a flare ytpe. If it is how do I flare something that small? My brake flare kit does not go that small. Thanks | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I think that fitting was used by GM into the 70s. It's actually a compression fitting. I haven't replaced one recently, but if IIRC just cut the end of the pipe off and slip a fresh pipe end into fitting. If your not comfortable using the old fitting NAPA has new fittings in their small parts bin.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | The inside looks just like a 1/4 or 3/16 female brake line type flare. I ended up putting the 1/8 nut on the copper line then I installed a compression fitting on the line. Next I cut the 1/8 compression fitting off the line leaving only the 1/8 flare type fitting with the compression ring. I then took the dremel and trimmed up the ferrule and tbg. It works great and I have about 35-40 psig | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | If its at all like an AD gauge then its a compression fitting. | | | | | Joined: Jan 2008 Posts: 4,992 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,992 | Eaton/Fuller transmissions use 1/8 plastic tubing with compression fittings for the shifter. I have used them before on 1/8 brass before. It may not be correct, but it worked. These fittings are available at heavy truck dealers. | | |
