5 members (Niels V, Phak1, MNSmith, 2 invisible),
77
Mod | | | Forums66 Topics128,180 Posts1,057,141 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | There's a port on the side and one on the bottom-which is which? also which one, inlet or return, is the one that the oil pressure gage feed off of at the block?
Keith | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | This has been discussed many times. The block outlet at the rear feeds the pressure gauge and the inlet of the oil filter on the side of the filter. The outlet on the bottom goes to the inlet on the block towards the front. Of course it could work both ways. I have photos of both variants on stock engines. | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Thanks for splain'n it one more time blu-I seem to remember my gage comming off the rear one..I suppose the ones that do the opposite did so by accident?
Anyone use teflon plumbers tape on these joints?
Keith | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No, don't use teflon tape on those fittings. If anything, use Permatex #2. Teflon tape can get into the system and plug up the passages, especially if it ovehangs the threads any at all.
Bill Burmeister | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There was some discussion about the filter being able to drain from the bottom when sitting. I am preparing a filter canister that I got off a 1951 216 in a truck. In this model, the bottom fitting is connected to the central tube and there is a restriction in the bottom outlet fitting. However, the only way for oil to pass into the center tube is through one tiny hole, up about 3/4 of the height of the tube. So I see two outcomes from this layout. First, the can will never drain just sitting there and number two the primary restriction is very small and is located on the side of the central tube. Oh, and there is a separate drain on the bottom of the can for servicing. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Dave, the link comes up as "Forbidden".
Bill Burmeister | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Thanks Bill, I tried it before I submitted it, and it gave me the "forbidden message, tried it again and it opened.....will give it another shot as a picture is still worth a 1000 words!! http://rides.webshots.com/photo/2292100550090459121nGskQJClick on "Full size" in the upper right corner to get a larger view of the filter plumbing setup. Dave
