| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | does anyone think this axle would work in my '47 AD 6400? i was trying to find a 3500HD axle and then i remembered i had this truck sitting outside it is a F120 axle. it would be nice if i could narrow it and have it fit good pictures http://community.webshots.com/album/564203282VwwlLU | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | Anything is doable, but an obsolete 12,000# axle with air brakes is not the kind of thing that makes sense to me. If you want a different steering axle, find a modern axle from a bob tail with hydraulic brakes. Probably could get by with just redrilling the u-bolt holes. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Front axle for AD 1.5 or 2 ton should have the following measurements: Center to center of spring center pin holes; 26 and 13/16 inches. Wheel mounting surface to wheel mounting surface; about 69.5" (within a 1/2").
So that axle would have to be narrowed approximately 20" that is way to much to leave you any spring pad to put the springs on. What is the present spring center distance on that axle? Subtract 20" from it, divide by two, and see if that far out from the existing center bolt hole you can put a new spring center bolt hole with u-bolt holes around it?
Even if the measurements worked out I agree with crenwelge, it's obsolete.
Also, the chances of finding a strong enough front axle that is both desirable and narrow enough to fit without cutting and welding (only re-drilling spring bolt holes) is slim to none, and slim just left. I have searched and searched for several years now for just that axle, and closest I have found is the P30 and or 3500HD axle, but they still need narrowing 8-10". As a side benefit these axles have the correct bolt pattern for and AD and slightly newer truck.
Grigg
