| | | Forums66 Topics128,186 Posts1,057,322 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43482 01/06/2003 6:14 AM | Joined: Nov 2002 Posts: 21 Apprentice | | Apprentice Joined: Nov 2002 Posts: 21 | Ok guys here is my question I'm going to go with a 1955 4 speed open transmission behind my 1962 235 and put in a blazer rear-end. Should I look for a 3.08 gearing or the 3.42 | | |
#43483 01/06/2003 6:31 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I have a 235 with a T-10 4 speed and a 3.42 rear. For now, I just use my truck around town and it's great (under 60). But if I were to do much highway driving, I would probably go with the 3.08 rear if you want to keep the 4 speed. I'm looking for a 5 speed to run with my 3.42. (best of both worlds I hope).  Good luck | | |
#43484 01/06/2003 6:37 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I found an RPM calculator that you can download. It will probably help you in your decision. http://www.5speeds.com/index.html | | |
#43485 01/06/2003 8:32 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Here is a whole collection of calculators that don't require downloading: Randy\'s Ring and Pinion calculators
#43486 01/06/2003 8:38 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I have a 261 and I'm planning on doing a 3.08 with the SM420 4 speed.
