| | | Forums66 Topics128,005 Posts1,055,266 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | I have a 54 1/2 ton with the optional hydramatic. Shifting in and out of reverse is quite stiff. Trans was rebuilt over 14 years ago but has less than 1500 miles since. Is there any linkage lubrication advice that may reduce this stiffness? Thanks Murray | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I would disconnect linkage and try to isolate where the bind is. Mine was stiff on the column where the swivel is that lets the lever pull forward and backwards. It sounds like yours might actually be under the hood on the column where the detent section is that the neutral start switch mounts to. | | |
