9 members (Gdads51, Bill Hanlon, dt235sd, Curt B., 3100RustyParts, Steveoreno, 68ironhead, Otto Skorzeny, Millenimech), 76 guests, and 1 robot.
Topics128,214
Posts1,057,487
Members48,473
Two years ago, it came apart after a couple of years' cruising. At first, I was just going to drop it off at a body shop, but one thing led to another and I decided to do it myself. (I'm glad I did, the plan changes almost day-to-day.) I had never welded or painted a thing in my life, but with a little practice I figured out how to use a mig welder and a spray gun. Today, I'm shooting the surfacer/sealer (that's PPG epoxy primer in the photos), next week the firewall will get color and the cab will go back on the frame. The rest of the sheet metal will get primered, hung and then off to the paint booth for the final bc/cc. (I know a guy that has his own personal paint booth.) With a little luck I'll drive it to the fall Goodguys in Charlotte.
I'm stoked!
More to follow . . .
http://picasaweb.google.com/ChrisAurit/BeforeAndAfter
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
Nice Job!
Hey,looks like you learned fast and good. Great lookin truck,I am sure you will enjoy it.
Nice job! It doesn't get any better than that - you're having fun working on your own truck and think of all that $$$$ you're saving!!
yep, coming along great desert_buick. looking good man.
keep the pics coming.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Maaate, that is an awesome looking rig!
It looks like you have been the only owner to give her a proper going over........not just a "Dulux Rebuild".
What method did you use to strip the old paint????????
keep up the good work!
"It's not a wreck......It's a natural resource!"
Quote-Doc Bob circa 2006
DOCS CLASSIC GARAGE
Specializing in Hot Rods,
Customs & Street Machines.
My pictures at..........
1936 Chev 1/2-Ton Holden Body
confused? http://www.koalanet.com.au/australian-slang.html
Hey Desert Buick!
What color is that? I really like it!! It would look good on my '58!!
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Thanks!
I tried just about all commonly used methods. I didn't like chemical 'cause it's too messy, same with sandblasting (I'm STILL blowing sand out of the nooks.) I ended up just using 6" stripping discs and bristle discs on a dewalt variable speed for the big flat panels and a small pneumatic angle grinder for the smaller areas and an electric drill and wire brush for the really small areas. It was a chore, but WELL worth the effort. (I sent the frame OUT for sandblasting.)
More pix in Picasa
Originally Posted by Old Gold
Hey Desert Buick!
Not sure what kind of turquoise, but I had it matched in a PPG single stage. The formula is here: http://picasaweb.google.com/ChrisAurit/BeforeAndAfter/photo#5228530525529087570
More pix in Picasa
Great to see the hard work payed off.
Nothin like elbow grease to get the desired result !
Well done.
DOCS CLASSIC GARAGE
Sure you're not a pro? Because your work is top notch, very solid. I think I'd better get my truck out of the shop and start learning like you did. Great work DB and a great looking truck, too.
Thanks, but I'll give credit where credit is due - the Stovebolt forums and the forums at autobodystore.com. Without the input from these two INVALUABLE sources, this thing doesn't happen.
More pix in Picasa
Excellent work, you must be a fast learner!!
