| | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 1 New Guy | | New Guy Joined: Jul 2007 Posts: 1 | 1948 chevy 4100 emergency brake goes to rear end it is disconnected from cable can I tap tab on backing plate back and forth to free it up ? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy banditosmith, yes you can do that, spray lots of your favorite lube on the backing plate, and tap tap tap away, good luck | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | I second that, use a hammer lightly at first, then heavier as needed. Careful not to smack the bleeder. I'd be careful about getting to much lube inside the backing plate, as brakes and lube don't generally work well together.
My thought, anyway.
-Michael | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | not sure how the ebrake set up is on 48 but it sounds the similar to my 38. on my 38 the cables were also frozen within the sleeve. do you have rods going to the cables then the cables attach to the lever going into backing plate? if so are the cables disconnected from rods and from the lever in the backing plate? inside the drum you find the lever attaches to the two pieces to expand the brakes these piviot points may also be frozen. with the brakes adjusted here may not be a lot of movement of the levers. I was able to get 1.5 ton reproduction ebrake cabeles thru antique auto supply in texas. now to make up new rods for the ebrake and i will be in good shape.good luck
I liked the transmission mounted ebrake on my 54 much easier to get working.
| | | | | Joined: Nov 2006 Posts: 5 New Guy | | New Guy Joined: Nov 2006 Posts: 5 | I pulled the e-brake lines off completely on a '53 4400, got a big aluminum pan and filled her up with WD-40 and gave those lines a bath for a couple of days. A little persuasion, a little coaxing, and a lot of patience - what choice do you have? Can't find those bad boys new anywhere on the planet, but at least my recipe worked for me. Good luck, Buddy.
Vintage Chevy Trucks Rule!
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | here is a tip to keep them working smoothly: melt them full of beeswax and they will work smothly forever. | | | | | Joined: Aug 2008 Posts: 22 New Guy | | New Guy Joined: Aug 2008 Posts: 22 | do what hack 85 says soak em in diesel or wd40. Left mine for 2 weeks in diesel. worked a treat. | | |
