2 members (46 Texaco, sron48), 146 guests, and 0 robots.
Topics128,119
Posts1,056,313
Members48,439
#433699 07/18/2008 12:57 AM
I have a pioneer keh 46-46 in dash casette that was given to me. It has all the wires but no schematic. I am hoping someone can tell me the proper wiring for the speakers.Thanks in advance, RON (peddlr)
Im not sure what that exact model is setup like, but typically Pioneer has a red for the switched power wire, yellow is the constant power wire, blue is usually power to an external amp. The speaker wires should be a set of greens, purples, grays, etc., where one of the wires has a line down it.
So one green may be a positive, while a green with a line would be negative. Youll have to play around and test it with the balance settings to determine left or right/front back, depending on how its setup.
Hope that helps some.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Moderated by  truckernix
