4 members (MickeyP, KEVINSKI, jay d, Otto Skorzeny), 153 guests, and 2 robots.
Topics128,034
Posts1,055,552
#43334 09/06/2003 7:04 PM
What are the torque specs for a '61 261 manifold?
My '48 shop manual for the 216 says center bolts=15-20 ft-lb and end bolts=25-30.
A previous post here for a 230 said center=25-30 and end=15-25. Is this backwards?
(I know, I know....I need a 261 shop manual.)
#43335 09/07/2003 10:23 PM
I don't know anything about a 230 engine.
The 1960 Shop Manual states "Tighten [inner] clamp bolts to 15-20 ft. lbs. torque and two end clamp bolts to 25-30 ft. lbs." for both the 235 and 261 engines.
Tim
#43336 09/07/2003 11:33 PM
Thanks, again, Tim!
#43337 09/09/2003 6:09 AM
My Chilton's manual has the opposite from the shop manual, so I've been a little confused also. Suspect the shop manual is the correct one. What give me more trouble is how do you get a torque wrench in there? Mine seems pretty standard, but there's no way I can get it inside the manifold on the bolt.
