0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43334 09/06/2003 7:04 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | What are the torque specs for a '61 261 manifold?
My '48 shop manual for the 216 says center bolts=15-20 ft-lb and end bolts=25-30.
A previous post here for a 230 said center=25-30 and end=15-25. Is this backwards?
(I know, I know....I need a 261 shop manual.) 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#43335 09/07/2003 10:23 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I don't know anything about a 230 engine.
The 1960 Shop Manual states "Tighten [inner] clamp bolts to 15-20 ft. lbs. torque and two end clamp bolts to 25-30 ft. lbs." for both the 235 and 261 engines.
Tim | | |
#43336 09/07/2003 11:33 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#43337 09/09/2003 6:09 AM | Joined: Feb 2000 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 41 | My Chilton's manual has the opposite from the shop manual, so I've been a little confused also. Suspect the shop manual is the correct one. What give me more trouble is how do you get a torque wrench in there? Mine seems pretty standard, but there's no way I can get it inside the manifold on the bolt. | | |
