3 members (dunfire, MikeE, carbking), 55 guests, and 1 robot.
Topics128,129
Posts1,056,360
Members48,441
#433273 07/16/2008 10:26 PM
trying to wire in an aftermarket gauge cluster in my 63 c10. im having a tough time reading the schematic and was wondering, should the fuel tank sending unit wire be going through the fuse box under the left side of the dash, or should it go directly to the gas gauge??
Since you have an after market cluster what do the instructions say?
Factory is direct from sender to gauge. The sender is a variable resistor to ground. Resistance is determined by float level in the gas tank.
Larry
I don't own a vehicle that isn't old enough to drink.
I agree with LGriffin. I have never seen the wire to the fuel level sender sent thru a fuse panel as there is no need for it. The 12 or 6 volt feed to the gauge is another matter.
Patrick,
If my poor old memory serves me, the gauge to sender wire does go to the fuse box, but only as a 'dumb' connection point...not through a fuse!
Stuart
oh wow so i could have saved myself a lot of trouble this evening tracing wires behind the fuse box and getting frustrated haha. well i used the one that went through the fuse box, oh well it still works. would it be more accurate without that connection?
also, hooked up my speedometer and it gets a little shaky whenever the transmission switches gears and then finally levels out. any way to fix this?
and also just so you guys know, these gauges were purchased from another bolter, so there are no instructions along with it.
