1 members (Southerntruck),
134
0
Mod | | | Forums66 Topics128,192 Posts1,057,353 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | Sometime in the future, I want to dump the old 216 with the crash box 4 speed, and install a newer 6 cylinder and transmission. I have a 46 1/2 ton. What combination would you recommend and why. I'm willing to go stick or automatic. I figured I'd start looking for good rebuildable cores once I make a decision. Oh yeah, rear end options as well. All replies are welcome.  Thanks, Possum
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | 4 speed Saginaw or 5 speed T5 (overdrive) if you are going to change the rear end.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | 302 GMC is a fairly easy installation unless you want more engine. A small block chev is a logical choice for that. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Oh boy, this should be an interesting can of worms. | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | The older, newer engines will be a easyer swap like Crenwelge suggested. A 235 or 302 might almost bolt in with a few minor changes.
The newer 230-250-292 will be more work due to motor mounts and crossmembers. With the 230-292's you can get parts at any local store, use about any transmission, and any late model rear axle. You need to decide what type of driving you want so you can gear it right, 3.08 to 4.11????
I like my 250 with T350 auto and 3.08 rear axle. It runs down the road at 70 mph and gets 16 to 18 mpg. Parts are easy to find and the swap was,t to bad. Joe
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Like Joe has if it is going to be a "car", if it is going to be a "truck", use a lower ratio rear end and an overdrive trans. | | |
