| | | Forums66 Topics128,140 Posts1,056,467 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 5,080 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,080 | Got this in the mail. Can you help this fellow, please? Sorry I was unable to get this email to go out through your website so I had to send it directly through my email. I just test fitted a T5 tranny (with clutch only) in my '72 c10 with 250 6 cylinder and with clutch bottomed out on the flywheel still have .938 before tranny bolts to bellhousing. Is the 235 bellhousing longer than the 250 bellhousing? Is that my problem or could there be another reason? Thanks Billy Register c10 [email protected] P.S I am using Astro 11 inch clutch disc.Thanks, Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The installation is the same but some modifications have to be made. The front of the input shaft & the front brg retainer have to be shortened to match the old trans. The mounting holes have to be drilled out to 1/2 in. The splines on the front shaft have to be ground so the disc will slide on 1/2 in further. You should put a crossmember under the trans. with a mount. Use a fine spline yoke from practically any 68 up chev. & have the drive shaft modified to fit. There has been many posts on this in this forum. You can get more info doing a search & in the Tech Tip section They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | In my humble opinion, it is much easier to have a spacer made to fit between the tranny and bellhousing. I made mine 1/2 inch. I tried all of the other modifications and it still wouldn't work. The spacer made it all work!!! | | |
