1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#432147 07/12/2008 7:55 PM
does anyone know what exhaust manifolds/headers will fit in a AD truck with a 454 big block? i was thinking about somthing out of a corvette or camaro.
Until very recently I'd claim never to have seen a 454 in an AD truck that had not been clipped or MII'd. But I saw one just a couple weeks ago. It has cast iron manifolds on it and a front steer power steering conversion. The steering is the challenge on a swap like this.
Billetproof NW Photos
Start with 100_4357.jpg and work you way through to 100_4374.jpg. These pictures are of a 1/2-ton AD with a 454 and I took detail pictures of a number of aspects of the install including what I could see of the power steering setup.
Just today I dragged a junk 454 into my shop prep to mocking up putting one in my AD 1-ton. I hope to use stock manifolds but haven't yet got the pieces close enough together to really know.
OldSub #432284 07/13/2008 6:56 AM
do you know what the manifolds are out of?
I don't know. I can see plugs in the manifolds, so they originally had air injection. I suspect once you solve the steering problem pretty much any stock manifold will work.
