3 members (Gdads51, Raymond HAYWOOD, IHPWR), 175 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#431765 07/11/2008 5:52 PM
I have a 55 2nd series that has an electric windshield wiper assembly that "looks" like it came from something else. It has 1 blue wire that is going to the switch and a plug that is hanging down unattached that has 2 wires-black and white. Any ideas on how to start wiring it up? Thanks, Hugh
Hugh,
I don't know what you have or how it was factory wired. I will say this. You mention only three wires. If the motor is supplied with power (fused) through one wire, that leaves two remaining.
Unless the ON/OFF switch completes a path to ground, I would surmise that the switch requires two wires from the motor to complete a circuit to turn the motor on.
This is only a guesstimate on my part. Good luck and welcome to the Stovebolt.
I know that the third terminal on a VW was used to park the wipers. Not sure how it worked but that is what the schematic says.
If you have a photo someone will be able to tell you if it is stock chevy. You can also go to one of the (auto-discount-oriley-quest-zone) sites and look at some of the suspected models, that is if you have a clue what the wiper motor might be.
You can link a digital photo by putting it on one of the sites that host photos webshots, photobucket, etc. Then cut and paste the address into your reply.
There is a tech help on how to do the photos in IT short bus on this site.
Good luck
for sure a pic of the wiper unit would help you get useful answers - if it's from another year or make or a 'generic' unit, each might be set up different - the switch will be relevent too, one position or 2?
Sorry to have taken so long to get back. Here is a photo:
[IMG]http://i231.photobucket.com/albums/ee39/h4040510/1955%202nd%20Series/WiperMotor.jpg[/IMG]
The Blue wire was fused so I hooked it up to +12 volts. The white and black wires then measured +12 volts each. I do not have a wiper switch but I figured that the switch must ground the wires to complete the circuit. When grounded, the black wire made the sound of a relay closing in the motor. When grounded, the white wire sounded like it wanted to turn the motor but didn't. Any further suggestions appreciated. This is a Delco unit but I could not see any numbers on it.
Hugh
Hugh,
This is still a toughie without having a switch and being able to do hands on mad scientist type work. I have enclosed a link to some pictures, one of which is a two speed wiper.
See if the diagram helps you any with wire functions.
http://community.webshots.com/album/76722164VVgaQA
Stuart
