3 members (Gdads51, 1955 1 Series, cmayna), 113 guests, and 2 robots.
Topics128,193
Posts1,057,249
Members48,466
Apprentice
Apprentice
anyone know how similar the 49 and 57 chassis are? As far as cab mounting I guess is my biggest worry.
The 57 is some wider than the AD and probably not a good choice unless you're into self-flagellation. I assume you have a cab for these frames?
~Jim
Apprentice
Apprentice
well, I currently run a 49 cab on a 71 chassis. Ive been looking for an original but have only found the 57 for a good price
If you want originality, I would go with a 48-55 frame. There is hardly any similarity between 49 and 57 frames. It would be doable but it would be a lot of work to accomplish really nothing. I was cleaning up here a while back and gave several parts pickups away that had good frames. Also, a GMC and a Chev 1/2 ton frame are different. Get one that is a bolt together and save a lot of work even if you have to buy a parts truck for a couple of hundred.
I really doubt you'll find an original frame. You will probably have to buy a junker 47-55 and part out the sheetmetal. The only reason not to use the original frame is to incorporate the IFS on the later model frame. Personally I would rather do a clip than to go through all that work.
~Jim
