4 members (cspecken, dt235sd, Wayne67vert, 1 invisible), 210 guests, and 3 robots.
Topics128,087
Posts1,056,112
Members48,434
#43116 12/23/2004 7:20 PM
I like to use a magnetic oil pan heater when it gets below 10 deg. in addition to the usual freeze plug heater. I put it on at night and take it off in the morning.
[img]http://www.sandeace.com/48/OilPanHeater.jpg[/img]
Does anyone know of a heater designed to be left in place while driving? The magnet on this on might be strong enough and I could cut off the handle but I'd like to see what might be available.
Thanks!! And yes, the exhaust pipe is too low.
#43117 12/23/2004 7:31 PM
Either jegs or summit has an oil pump heater. It has the heater element encased in a sleeve which is welded into the oil pan.
Jason
#43118 12/23/2004 8:01 PM
Hi Wally,
I bought a heater for my wifes car when it was having trouble starting in the winter that you leave in place. I never installed it because we found out that the coil was bad and when we replaced that, it started fine. This one installs on the heater hoses and when plugged in, circulates the water in the raidator and block to keep things warm. I have been going to install it on my tractor as the heater hoses are just looped to keep the heater from leaking, but havent gotten around to it. Could use it today as its 6 degrees here today without the wind chill. Hope that helps. My 48 3/4 ton always starts, so I dont mess with it wink
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
#43119 12/23/2004 10:10 PM
There are "dipstick" heaters that warm the oil and can be left in place while driving, but the percolator heaters that are plumbed into the heater hoses will probably do a better job of keeping the entire engine warm, plus you'll have heater operation almost immediately.
#43120 12/23/2004 11:47 PM
Jason, I like the idea of a heater right under the oil pump. Is it just tacked on with welds?
The last time I looked in the applications book, only a freeze plug heater was listed for the 235/261. Some engines don't have the right convection circulation patterns for a tank heat (heater hose) or a lower radiator hose heater. The heating element overheats.
I had a 1500 W tank heater on a 283 when I lived in Wyoming. One hour is all it took in very cold weather.
Jason, I like the idea of a heater right under the oil pump. Is it just spot welded?
#43121 12/23/2004 11:49 PM
Guess Who?
Up here folks use a Silicone Pad (5x7 +/-) stuck to the bottom of the pan. The auto stores have a basket full, I think they have the plug built on now.
Site in post below.
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#43122 12/23/2004 11:58 PM
Wally, I was assuming that you want to heat the oil; possibly in addition to the coolant. I have used a tank heater with good results on my 302. But they don't heat the oil.
The oil heater is Jegs p/n 861-6770. You drill a hole in your pan, weld a bung on, and screw the heater in. It has a stainless sleeve to prevent direct contact with the element. I have not used this heater but I like the concept.
Jason
#43123 12/24/2004 12:01 AM
'50 GMC Suburban
#43124 12/24/2004 1:20 AM
Thanks, guys! I like my freeze plug heater for what it does but I'm also interested in heating the oil. My old 235 and new 261 start just fine when it's cold but I want to baby the 261.
Jason and Buddy, It's interesting that those products are designed for racers who don't want to start their engines when it's as cold as 65 degrees!
Jeg's unit heats the oil from 60 deg. to 180 in 45 minutes. One of the Moroso oil pan pads heats from 66 to 160 deg. in 25 minutes. Moroso has another lower wattage pad that my freeze plug heater can keep up with. I think I'll get that one.
Thanks, everyone.
#43125 12/24/2004 4:30 AM
Wally,
Nice to hear that you are taking care of that 261. What did I just see, is it about 15 degrees there now??? Gotta love it. I defintely miss those days.
Oh, by the way, it was about 73 degrees here today cool .
Keep that old engine warm! Talk to you soon.
Steve
55 1st Series 3/4 ton
#43126 12/24/2004 8:00 PM
Hey, Steve! We spent two years in Gainesville so I know what you're "going through." Do you ever use the Griz Cam to see what you're missing? It's been a lot nicer here than back east.
I'm taking care of that 261 so I don't have another 18-months of working on the truck in the driveway. That included two winters!
Merry Christmas to you, yours and all Stovebolters!
#43127 12/28/2004 12:06 AM
Rather than running a block heater or pan heater all night try putting it on a timer. Just takes about an hour or so to get hot enough. Saves running electricity all night.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#43128 12/31/2004 3:06 AM
Wally,
I have checked out the Grizcam from time to time. It does make me miss the mountains a little....until I realize that it is December 30th and it is 76 degrees! A far cry from the cold winters working on the trucks in the uninsulated, unheated garages out there.
Was that sound file you sent me from the engine running in the winter?? If so, man that sounds good.
Steve
#43129 01/03/2005 5:13 AM
Steve,
The sound file was recorded after driving the 3 miles home. I posted some links to other sound files in a post in the "General" area call "Listen to my 261." Even the smoothest, quietest engine has some pretty violent stuff going on inside.
Happy New Year.
#43130 01/04/2005 7:12 PM
They do make ones that stick on as well. I don't have one but my boss has used them on his Cummins diesels with great luck. They are 4X4's and he travels through winter roads and has not lost one yet.
Shop around, maybe check www.canadiantire.ca
Blaine Dumkee
59 GMC 9314
Fort Smith NT
www.flickr.com/photos/northerngmc/
