| | | Forums66 Topics128,083 Posts1,056,326 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I really like clamshell front ends. Maintenance is so much easier. Does anyone know a source for fiberglass parts for Early '50 Chevy trucks?
I'm not holding my breath for a reply on this one.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | I like the look, and I like being able to get in and work on the engine. Has anyone done this with the factory sheet metal? | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I did the front end on a Pontiac Ventura II eighth miler once. It wasn't too bad even without pneumatic cylinders.
I think that the sheet metal on a Chevy truck might be kind of heavy.
Basically, you just weld or rivet the fenders to the hood, build a tubular frame that supports the hood, and put the hinges in the front. No need to cut the bottom rear parts off the fenders because there is no noticeable curvature there.
| | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | You will have to cut the front fenders because of the way the front fenders wrap around the bottom of the cab. I have seen it done this way before. I like the idea of a tilt front end, but the cut in the front fenders ruined the look.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Sorry, 53GMCPhil, you are right. It can be done neatly, but it requires some fabrication.
