1 members (Otto Skorzeny),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 54 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 54 | Has any of you folks ever installed a power glide transmission on a 235 engine in a 47-54 Chevrolet truck? I have been told there are some clearance issues, I was told the transmission will hit on the body. Any ideas or suggestions would be greatly appreciated. I don't want to change the engine because it performs so good. I currently have a 3 speed transmission, but would love a automatic transmission. A power glide is the only tranny that will connect to a '57 235 engine. As always thanks a bunch. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Actually, Langdons has an adapter plate that allows a 235 to be bolted up to a later GM automatic, like the 700R4. http://www.stoveboltengineco.com/howto/trans.htmThis would be a better choice over the 'Glide for a driver, as yu'll gain an overdrive gear for better economy and more comfortable highway rpm.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Yeah, what LONGBOX said, and also the Powerslush gets you moving from a dead stop at about the same rate as a Whizzer motorbike. The TH350 or 700R4 gives you a nice low gear to start out on. | | | | | Joined: Aug 2004 Posts: 54 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 54 | I was always told the 235 engine didn't have the torque needed for a smooth operation on a 700R, is this true? Does the 200r4 meet the requirements better? Which of these 3 trannys should produce the best gas mileage and everyday driveability? Thanks guys, I did stop the power glide install.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't think torque is an issue with the 235, I have an S10 with a 2.8, far less torquey than my 235, it turns a 700R4 just fine. I beleive that the 200 4R weighs less, and might be narrower in width, and I'm certain it costs less, but the 700 has a better first gear and is a stronger trans (GM used them in 3/4 tons trucks). Either one would be fine, although I would think the 700 would have a better in town performance due to the first gear.
Bill Burmeister | | | | | Joined: Aug 2004 Posts: 54 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 54 | Thanks Bill for all of your responses, you will never know how much you have helped a dummy. MAYBE one day I can help you | | |
