6 members (37 GC, klhansen, Shade Baby, Reftys49, MaxStewart, Philipj), 95 guests, and 1 robot.
Topics128,143
Posts1,056,786
Members48,454
#429795 07/06/2008 3:46 AM
Has any of you folks ever installed a power glide transmission on a 235 engine in a 47-54 Chevrolet truck? I have been told there are some clearance issues, I was told the transmission will hit on the body. Any ideas or suggestions would be greatly appreciated. I don't want to change the engine because it performs so good. I currently have a 3 speed transmission, but would love a automatic transmission. A power glide is the only tranny that will connect to a '57 235 engine. As always thanks a bunch.
Actually, Langdons has an adapter plate that allows a 235 to be bolted up to a later GM automatic, like the 700R4. http://www.stoveboltengineco.com/howto/trans.htm
This would be a better choice over the 'Glide for a driver, as yu'll gain an overdrive gear for better economy and more comfortable highway rpm.
Bill Burmeister
Yeah, what LONGBOX said, and also the Powerslush gets you moving from a dead stop at about the same rate as a Whizzer motorbike. The TH350 or 700R4 gives you a nice low gear to start out on.
I was always told the 235 engine didn't have the torque needed for a smooth operation on a 700R, is this true? Does the 200r4 meet the requirements better? Which of these 3 trannys should produce the best gas mileage and everyday driveability?
Thanks guys, I did stop the power glide install.
I don't think torque is an issue with the 235, I have an S10 with a 2.8, far less torquey than my 235, it turns a 700R4 just fine. I beleive that the 200 4R weighs less, and might be narrower in width, and I'm certain it costs less, but the 700 has a better first gear and is a stronger trans (GM used them in 3/4 tons trucks). Either one would be fine, although I would think the 700 would have a better in town performance due to the first gear.
Bill Burmeister
Thanks Bill for all of your responses, you will never know how much you have helped a dummy. MAYBE one day I can help you
