3 members (Gray_Ghost, Steelonsteel, Gdads51), 46 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#430793 07/08/2008 10:36 PM
I want to replace the lever shocks on a 49 with tubular type and have taken the mounts from a 53 frame and made a fairly accurate template of where to mount the brackets on the 49 frame.
How 'bang-on' does this template need to be. If I am off a 1/2" or so will it make a difference to the shock performance?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
You'll want to err more towards a vetical mounting. They shouldn't be mounted at any more that a 45 degree angle, max. The also need to be mounted them same on both sides.
Bill Burmeister
I'm putting new shocks and mounts on my '46 Panel and the instructions say at full extension the shock should be mounted at 26-27 degrees inward( lower to upper ) that will put them 30 degrees at ride height. Front to rear should be as vertical as possible if not dead on.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
