| | | Forums66 Topics128,265 Posts1,058,364 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 9 Apprentice | | Apprentice Joined: Feb 2008 Posts: 9 | I'm converting to 12V in my '41 1/2-ton canopy (on its way to actually becoming a truck again, sted a large potential fishing reef). Is there a specific 12-volt generator that will drop in without much trouble? It's on a 216 babbit-pounder with 5/8 pulley. Also, same question about regulator: Is there an easy replacement? Thanks. Will Corbin [email protected]850-420-0947 | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I have a generator, ready to go if I ever decide to convert. I believe that it is from a 55 Chevy sedan but the main thing is it appears to have very similar dimensions. The regulator looks almost identical. | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Consider a 'single wire' 12 volt alternator unless you are trying to maintain originality. You're going to have to change the same parts for the switch to 12 volts, but I think that the alternator will be better in the long run.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | Just about any 12 volt GM generator will swap, you just need to change pulleys. Most of the 12 volt units ran the narrow belt, but it's a quick switch to install the wide-belt pulley off the 6V generator. Of course, you'll need the corresponding 12V regulator to work with the generator. That's a straight-across swap also, using the same wires. Jerry
