3 members (Wally / Montana, Sjm, Peggy M), 136 guests, and 4 robots.
Topics128,264
Posts1,058,357
Members48,485
Apprentice
Apprentice
I'm converting to 12V in my '41 1/2-ton canopy (on its way to actually becoming a truck again, sted a large potential fishing reef). Is there a specific 12-volt generator that will drop in without much trouble? It's on a 216 babbit-pounder with 5/8 pulley.
Also, same question about regulator: Is there an easy replacement?
Thanks.
Will Corbin
[email protected]
850-420-0947
I have a generator, ready to go if I ever decide to convert. I believe that it is from a 55 Chevy sedan but the main thing is it appears to have very similar dimensions. The regulator looks almost identical.
1951 1 Ton Completed
Consider a 'single wire' 12 volt alternator unless you are trying to maintain originality. You're going to have to change the same parts for the switch to 12 volts, but I think that the alternator will be better in the long run.
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
Just about any 12 volt GM generator will swap, you just need to change pulleys. Most of the 12 volt units ran the narrow belt, but it's a quick switch to install the wide-belt pulley off the 6V generator. Of course, you'll need the corresponding 12V regulator to work with the generator. That's a straight-across swap also, using the same wires.
