1 members (JW51),
137
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 31 Apprentice | | Apprentice Joined: Sep 2007 Posts: 31 | All,
I have a '49 3100, need to get the rear drums off. It is not the original rear axle, it is a 5 lug older GM, from that era I believe. It is a drop out third member type axle (similar to 9" if that makes sense). Not rusty and I backed the adjuster in all the way (I think). The drum will move a little - can see it move by the lug nuts, just will not come off.
ANy tips?
Scott
1949 5 Window 3100
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Might be hung up on the hub. Try shooting some Kroil or PB on it in that area, and perhaps lightly sand the hub ti take any rust off. One trick that's worked for me is to get a couple of small (about 18" ) prybars to get in between the drum and backing plate to apply pressure. I'm not talking about any major force here, just enough to get some pressure to help pop it off. Then give it some solid whacks, preferrably using a brass hammer. That usually works for me with no damage to the drum or backing plate.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If the drums are old, they may have a grove worn and this is what the shoes are catching on. About all you can do is make sure you back them off as far as possible. You might have to use a pry bar if you are planning on replacing shoes anyway. We have gear puller in our shop that makes them come off so easy you think they should have fallen off. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Welcome, I've found that if the drums have been on for a long time they can be very difficult to get off period. Your on the right track, after backing the adjust off I "hammer" on the drum while pulling and prying. I think the old shoes wear grooves in the drum and you have to get the drum to clear the shoe. You might want to make sure your emergency brake cable is not holding you up. The other problem is the wheel cylinders are frozen up and the shoes won't back off. Cussing and hammering has always worked for me. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | You can tell if it is hanging on the brake shoes if it kind of springs back on you when you try to pry it off. If it is hanging on anything else it will come to a dead stop and not feel like it is trying to move back. Make sure the adjuster is all of the way in and try tapping the drum with a 2x4 or brass hammer to get the shoes to move in. Is this a truck that has been running or sitting? I also almost worked myself to death once on one that had been sitting up. I figured out that the parking brake cable was rusted stuck and the shoes weren't comming all the way in.
Neil | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Try turning the drum and pulling at the same time. And like everyone has said be sure the adjusters are backed off. Cleon | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Just hammer the heck out of it. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Go to your local FLAPS and rent / borrow a brake drum puller (I think crenwelge mentioned it as well)
| | | | | Joined: Sep 2007 Posts: 31 Apprentice | | Apprentice Joined: Sep 2007 Posts: 31 | The truck has been running, I think the shoes have worn slots in the drums.
1949 5 Window 3100
| | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | Like stated above, make sure the adjusters are backed off so the shoes are not causing the problem. IF the adjusters are stuck you can take the retainer washer off the pin and pull drum and shoes together, although this does not work very well.
The EASY way, and I do mean EASY, to get drums off rear axles is to heat the drum with a propane torch right around the wheel stud area. DO NOT HEAT THE AXLE HUB itself. You are only wanting to heat the drum to expand it slightly so it will slip right off of the hub. You do not need a lot of heat--just slightly more than what you can stand your hand on for a second or two.
In a particularly stubborn case I once had to run a water hose on the axle/drum assy until the axle was as cool as the water coming out of the hose. I then used a torch as described above and the drum almost fell off.
BTW this trick works on anything with outboard drums, from pickups to semi trucks. | | | | | Joined: Aug 2005 Posts: 124 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 124 | If you have the truck in a shop where air pressure is available, you can put a flatheaded tool into you air hammer and hammer in the area between the studs over & over. this works very well! | | | | | Joined: Jun 2007 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 90 | I'll usually take a torch and heat up the area around the lug nuts and hub until I hear a satisfying *BANG* that means the drum has separated from the hub. This works in cases where the drum is rusted to the lug nuts and hub. | | |
