0 members (),
124
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | My truck has been driving great. But yesterday...and again today, as I was coming up my hill in third gear (as usual) I noticed I was losing power, almost like it was chugging. It was fine going up till I got to the steepest part, then it was as though I was getting starved for gas. Stepping more on the gas didnt help.
I put a new fuel filter in just last fall. I changed the air filter when I got home, but it didnt look that dirty to me. Havn't taken it out again due to heavy rains
Can some one give me some other possible causes for this sudden occurance. Have had the truck 6 years, and havn't experienced this before. Thanks.
| | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | Bad Fuel pump or clogged filter would be my guess. Anytime I have had a problem with it starving for fuel on a hill that was the cause. Something is causing the fuel level in the float bowl to be low and as you go uphill the angle of the float bowl changes and causes the lack of fuel. I would check the pump pressure after the filter.
Good luck Neil | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | good tips , what would happen if you shifted into 2nd.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Check the filter, float, accelerator pump and fuel pump in that order. Also check your gas level, your gage may be off too.
I am pretty sure this is not the problem, but a dented gas tank can be the culprit too. Sometimes a dented gas tank can move the gas away from the fuel line causing the engine to starve when climbing hills. But in your case you said that the truck has been running great until yesterday.
Wouldn't hurt to check your wires either. Once in a while a loose wire on the ignition or coil will give the same effect when climbing a hill. It feels like it is starving or chugging. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | These new fuel mixtures will about eat anything they touch, of the rubber persuasion. On a tour a couple of weeks ago, three of us lost our fuel pumps before the day was done.
I've since put a 6-volt electric on my 52, and haven't had a problem. In fact, it sure starts up alot easier than it ever did before. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | May not hurt to check your vacumn advance.....and may as well check the timing just in case. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Did this strange occurance start before all of the heavy rains or after ? Could be water in the fuel or distributor cap is wet. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | Thanks everyone...I'll check all those things you mention,.. or more precisely, have my mechanic check them.
Joker: don't know, I stayed in third since I was going too fast to shift to 2nd. Bowtie: nope, it was dry. I don't take it out of the garage in the rain.
I appreciate everyone's help. Will let you know what the cause ends up being.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | is this a four speed or three............
I just thought if it was lugging down going up a hill, you might down shift one gear to see what would happen..
good luck with the gremlin Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | these new fuel mixtures will about eat anything they touch, of the rubber persuasion. use only the VERY best fuel line $$ can buy @ $6.00/foot NOT the cheap stuff anymore. believe ME maybe do this http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=582585-R1-048-22A.jpgif'n you have a tank that empties from the bottom.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | joker..its a three speed. But , I have been taking this hill happily at 40- 45 mph in third gear for 6 years, never a problem till now. thks | | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | hey you might wnat to check the float in the carb it might have a pinhole leak in it | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If you have a tank behind the seat, check the elbow or fuel shutoff at the bottom of the tank. That spot is notorious for catching trash. | | | | | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | Ok guys...It WAS the Fuel Pump.!!! New one being installed weds.
Thanks again for all your expert assistance. | | | | | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | SO!! New NAPA fuel pump for the '55 235 chevy engine ended up being a dud. Drove out of the shop went 75 yards and it went dead. My mechanic came to my rescue, and saw the fuel filter wasn't getting nearly enough gas. Pushed it back to the shop, new pump due tomorrow.
Why is it nothing is ever easy??? (yes.. '55 engine in a '51 1/2 ton)
| | | | | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | Final entry: New NAPA pump is perfect! Between the newly cleaned out carb, and the new fuel pump I'm getting plenty of gas, and its running smooth as silk...even up the steepest hill.
Thanks everyone for your help. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm assuming from the picture and text that you are advocating soldering a pipe in to the tank with a screen soldered over the end to catch rust or other junk that might get into the fuel line?? So what do you de when the screen gets cloged with crap, that is how do you clean that? Denny Graham Sandwich, IL
Denny G Sandwich, IL
