4 members (Joe H, 68ironhead, baldeagle, 78buckshot), 72 guests, and 5 robots.
Topics128,014
Posts1,055,329
Members48,419
#429879 07/06/2008 1:51 PM
Installed a new master cyl. last week. it is leaking around the area where it bolts to the vaccum cyl. Is it bad or did I do somthing wrong?
gazim #429887 07/06/2008 2:18 PM
having problems on my new install myself, but not that exact problem.
did you bench bleed the master before you installed on the truck ?
my instructions say put master in a vise, fill with brake fluid and wait 10-15 minutes, to let the fluid get around the shaft seal. then procede to bench bleed, pushing in on the master rod very slowly, and releasing.
see, if you dont get fluid around the seal, it says it is possible to roll that seal over and damage it.
not sure if that is your problem, but if you didnt bench bleed maybe that is it.
good luck..i totally hate brake systems now, thanks to all the trouble i am having with mine..
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
RATRODKING #429899 07/06/2008 3:21 PM
Riding in the Passing Lane
If it is leaking around the front piston you have a defective MC.
1972 Chevy c10 Cheyenne Super
I bench bleed it, Will remove it today to see what is wrong maybe. I suspect a defective cyl.
