| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I am putting the hood back on my 49 Suburban. It seems the hood lock bolt is too short to fully engage and catch on the lock plate. The safety catch is aligned and engages as it should. The front of the hood is touching the top of the grill so it doesn't seem to be the issue. I have had all the front sheet metal off the truck but everything looks to be aligned as far as fenders grill etc. goes. The hood latch bolt has 1/4 inch of thread showing at top of bolt that could be adjusted to lengthen the bolt but wanted to ask for any suggestions to see if I am missing something. Any other thoughts?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If the bolt is too short why not try raising the latch plate? I'd try putting some washers under the plate until it latched. If it took more than two I'd start investigating why things aren't the way they should be. I'm assuming that your latch looks like THIS | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Woody, that’s not how it’s supposed to look, it’s supposed to be cad plated!!! http://rides.webshots.com/photo/2910928080098611668FefUPB http://rides.webshots.com/photo/2769712380098611668NFrhMp Just pulling your jeeber buddy, here’s a couple more pics for Sid to look at. The pin has about a 1/4” of thread showing beyond the nut. Are your sure the hood wasn’t slammed shut hard and the cross member in the nose of the hood bent or pushed up into it?? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | once you got this one fixed .....you could also add this...just a thought That's really cool!... but yours is the wrong color too. Now go stand over there in the corner until you learn to behave yourself.  | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Guys Thanks for the input. Caroline i like the lock idea for the hood. I put a nova clip on the frame and I had someone suggest the sheet metal may be a fraction too low which makes sense. I'll play with it until I get it figured out cuz I am too stubborn to give up:)
Can someone please measure the length of the brace rods from back bolt to the L bracket on fenders? The shop manual shows different lengths which confuses me.
