4 members (greenie-reddy, pauld, 2 invisible), 85 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#429538 07/05/2008 2:42 AM
Is there a support of some sort that goes behind the grill on a 47-53. I haven't seen anything in the catalogs but I had an ole timer tell me there was. I seem to have more "give" towards the bottom than it seems like I should.
regmudd
What you should have is one of these, http://www.flickr.com/photos/26014986@N07/2445813793/ The entire front end depends on it. Other than that I'm not sure if this is the part you mean. There is a lower panel that goes between the grill and radiator support.It has a hole for the starter handle. Is this what you require?
More pix on Flickr.
You should have 2 rods supporting the lower splash apron and grill. They attach to the center of the grill at the bottom and to the top of the radiator support. Cleon
[IMG]http://thumb19.webshots.net/t/58/758/2/23/33/2879223330098468599FYhFgc_th.jpg[/IMG]
1949 Chevy 6400
1931 Chevy Firetruck
Cleon...You've got me worried now! big_eek My 50 doesn't have these,but it does have the core to firewall ones.
Were these rods in your pics not just fitted to the bigger'bolts?
I'm curious now,as I haven't noticed these before on the smaller A.Ds i.e 1/2 ton and 3/4 ton. headscratch
John.
I meant inner fenders not 'core'
More pix on Flickr.
I have those on my '51 1/2-ton.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
My 51 1/2 ton Panel has them as well.
It's easier to get older than it is to get wiser.
regmudd, get a factory assembly manuel!! Most all of the vendors have them!!
I can't find any info on these brackets in the factory assembly manual... do you have a Section and Page for it?
Woody
Door Art Collection
