| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 56 | I have a 65 C-10 and the driver door is sagging. I can pick up on the bottom of the door and rotate it up about 1/4". I found a hinge repair pin from LMC. Does anyone have experience with this product and how difficult is it to install? What should I expect for results?
Thanks for your advice.
| | | | | Joined: Feb 2007 Posts: 28 New Guy | | New Guy Joined: Feb 2007 Posts: 28 | I havae used the sets and found them to be very good quality. If the hinges are in really bad shape, I suggest a good deburring tool to smooth out the inside, and/or a rat tail file with maachine oil to clean the insides out. You may also find the pins to be excessively long, After doing the first one, I measured and cut them to length. Been happy with them since.
Jim Elder Pembroke Pines Florida 64 GMC Stepside Grandaddies Truck Purchased New March 1964 AR Dyer Buick Hardinsburg Kentucky
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Are you the same PicloMike from Nikon Cafe? | | | | | Joined: Sep 2007 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 56 | Thanks...I order a pair and give them a try. | | | | | Joined: Sep 2007 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 56 | Sorry Czechman...not the same. | | |
