| | | Forums66 Topics128,033 Posts1,055,531 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | Is there a support of some sort that goes behind the grill on a 47-53. I haven't seen anything in the catalogs but I had an ole timer tell me there was. I seem to have more "give" towards the bottom than it seems like I should. Thanks, regmudd | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | What you should have is one of these, http://www.flickr.com/photos/26014986@N07/2445813793/ The entire front end depends on it. Other than that I'm not sure if this is the part you mean. There is a lower panel that goes between the grill and radiator support.It has a hole for the starter handle. Is this what you require? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Cleon...You've got me worried now!  My 50 doesn't have these,but it does have the core to firewall ones. Were these rods in your pics not just fitted to the bigger'bolts? I'm curious now,as I haven't noticed these before on the smaller A.Ds i.e 1/2 ton and 3/4 ton.  John. I meant inner fenders not 'core'
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I have those on my '51 1/2-ton. | | | | | Joined: May 2007 Posts: 46 New Guy | | New Guy Joined: May 2007 Posts: 46 | My 51 1/2 ton Panel has them as well.
It's easier to get older than it is to get wiser.
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | regmudd, get a factory assembly manuel!! Most all of the vendors have them!! | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | regmudd, get a factory assembly manuel!! Most all of the vendors have them!! I can't find any info on these brackets in the factory assembly manual... do you have a Section and Page for it? | | |
