| | | Forums66 Topics128,282 Posts1,058,492 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 10 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 10 | I'm just about to install the new weathersrip on the doorframes. Is there a particular adhesive I should use, or just regular contact cement? | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Check at your local FLAPS. Most carry weatherstripping adhesives. I used Permatex Super Weatherstripping Adhesive on my 4t6 window strips. Very much like contact cement you apply one coat to both surfaces and let dry then apply a wet coat and install. It seemed to stick very well. I think the key is to make sure surface is clean. Good luck and have fun Dan | | | | | Joined: May 2007 Posts: 46 New Guy | | New Guy Joined: May 2007 Posts: 46 | Regular contact cement will work if you like the look of yellow adhesive sticking out from under the molding. The weatherstripping stuff is black and doesn't show.
It's easier to get older than it is to get wiser.
